Displays protocol filter definitions and the complete protocol configuration.
| filter | Displays a protocol filter. |
| name | Displays a protocol filter name. |
| detail | Displays protocol information in detail. |
Displays all protocol filters.
Displays the defined protocol filter(s) with the types and values of its component protocols.
The following is an example of the command's output:
# show protocol
Protocol Filter Name Protocol Id Destination Field Field Field
Type Value Address Offset Value Mask
IP etype 0x0800
etype 0x0806
ANY ANY 0xffff
ipx etype 0x8137
IPv6 etype 0x86dd
lacp etype 0x8809 01:80:C2:00:00:02> 14 01 FF
mpls etype 0x8847
appletalk snap 0x809b
snap 0x80f3
> indicates that the value was truncated to the column size in the output.
Use the “detail” option to see the complete value.
The following example displays the show protocol detail command:
Protocol Filter Name : appletalk
Protocol Id Type : snap
Protocol Id Value : 0x809b
Destination Address:
Field Offset :
Field Value :
Field Mask :
Protocol Id Value : 0x80f3
Field Offset :
Field Value :
Field Mask :
Protocol Filter Name : lacp
Protocol Id Type : etype
Protocol Id Value : 0x8809
Destination Address: 01:80:C2:00:00:02
Field Offset : 14
Field Value : 01
Field Mask : FF
# show protocol filter “lacp” detail
Field Offset : 14
Field Value : 01
Field Mask : FF
The following example displays the show protocol filter command:
Protocol Name Protocol Id Destination Field Field Field Tagged
decnet etype 0x6003 No
etype 0x6004 No
myPvst snap 0x010b 01:00:0c:cc:cc:cd Yes
netbios llc 0xf0f0 No
llc 0xf0f1
The filter and detail keywords were added in ExtremeXOS 15.5.
